Starter Problem?
definately sounds like the solenoid is binding up. Check for a good batter, then the ground from the battey Neg. to where it attatches to the body for tight connections, check tight (and clean) connections to the starter, and check that the starter is tightly bolted to the bell housing since the ground is the case of the starter. If all that is good than it is DEFINATELY a bad starter.
