amol_pat Posted October 18, 2007 Share Posted October 18, 2007 Dear Members, I own a 1995 lexus ES300 and had my CV joint replaced recently. I have now realized that the ABS speed sensor is damaged and should be replaced. I don't want to spend on a new sensor (costs more than $100). So I searched for a used lexus part at junk yards but no luck.. I was wondering if a used Camry part would work? If so which years? Any suggestions are appreciated.. -A Quote Link to comment Share on other sites More sharing options...
Corpse Grinder Posted October 19, 2007 Share Posted October 19, 2007 Dear Members,I own a 1995 lexus ES300 and had my CV joint replaced recently. I have now realized that the ABS speed sensor is damaged and should be replaced. I don't want to spend on a new sensor (costs more than $100). So I searched for a used lexus part at junk yards but no luck.. I was wondering if a used Camry part would work? If so which years? Any suggestions are appreciated.. -A I found a site that sells them, as I am in the same boat. Although it doesnt say what model or year they are for, under description it just says ABS Speed Sensors for Lexus/Toyota. I just assumed that the ABS systems are all the same, and the type of car would not matter... They are $22 Sensor and wiring... Quote Link to comment Share on other sites More sharing options...
amol_pat Posted October 19, 2007 Author Share Posted October 19, 2007 Dear Members,I own a 1995 lexus ES300 and had my CV joint replaced recently. I have now realized that the ABS speed sensor is damaged and should be replaced. I don't want to spend on a new sensor (costs more than $100). So I searched for a used lexus part at junk yards but no luck.. I was wondering if a used Camry part would work? If so which years? Any suggestions are appreciated.. -A I found a site that sells them, as I am in the same boat. Although it doesnt say what model or year they are for, under description it just says ABS Speed Sensors for Lexus/Toyota. I just assumed that the ABS systems are all the same, and the type of car would not matter... They are $22 Sensor and wiring... Thanks for letting me know.. I have been checking through various websites and it seems like the part number is same for the same year Toyota Camry V6 model. I don't get the impression that the part is same for all the years though.. The lowest price I have seen is $98.00.. Can you please tell me the website you looked at? The cost seems a lot lesser there.. thanks, -A Quote Link to comment Share on other sites More sharing options...
amol_pat Posted October 21, 2007 Author Share Posted October 21, 2007 After a lot of phone calls, I found the sensor at the local junk yard... it was a camry part. It did not fit in the hole easily; so I had to shave off some of the plastic at the base of the sensor and finally it went in.. THE ABS LIGHT IS GONE!!!! whew! thanks for the replies.. -A Quote Link to comment Share on other sites More sharing options...
