qha_vn Posted October 9, 2007 Share Posted October 9, 2007 anybody thinks that we can get kind of signals from the tranny that indicates the current gear No. in some car like Mazda 3 AT, there is a gear number indicator says 1,2,3,4...etc when the tranny shift automatically from 1 to another. looking to the number we know that it is running at which gear and when it shifts to another, quite useful huh? any thoughts? Quote Link to comment Share on other sites More sharing options...
qha_vn Posted October 23, 2007 Author Share Posted October 23, 2007 well, i read the repair manual for A340E automatic tranny on 1UZFE. this is quite simple to achieve if you connect a voltmeter to terminal TT (+) and E1 (-) the volt changes will indicate gear position as in table below Gear position/ Terminal TT output voltage 1st gear/ below 0.5v 2nd gear/ 1.5-2.6v 3rd/ 3.5-4.6 O/D/ 5.5-6.9 with some skills on electronics, we can make the output human readable Quote Link to comment Share on other sites More sharing options...
pishta Posted October 24, 2007 Share Posted October 24, 2007 well, i read the repair manual for A340E automatic tranny on 1UZFE. this is quite simple to achieveif you connect a voltmeter to terminal TT (+) and E1 (-) the volt changes will indicate gear position as in table below Gear position/ Terminal TT output voltage 1st gear/ below 0.5v 2nd gear/ 1.5-2.6v 3rd/ 3.5-4.6 O/D/ 5.5-6.9 with some skills on electronics, we can make the output human readable Use a muti-segment LED voltmeter that measures .1v to 6V and has maybe 4 LED's Or a small analog meter that has a new scale printed showing you what gear you are in as it relates to volts. Quote Link to comment Share on other sites More sharing options...
