Bardonia Posted September 18, 2007 Posted September 18, 2007 Several parts of the ES350 manual are very unclear. For example, on page 229, Section 3-4 entitled ‘Using the Interior Lights’ it says; 1) Door position OFF/ON The illuminated entry system is activated when the switch is not in the locked position (the door position is on). 2) ON/OFF Can someone explain this? Thanks Bardonia
sharpcolorado Posted September 19, 2007 Posted September 19, 2007 Several parts of the ES350 manual are very unclear. For example, on page 229, Section 3-4 entitled ‘Using the Interior Lights’ it says;1) Door position OFF/ON The illuminated entry system is activated when the switch is not in the locked position (the door position is on). 2) ON/OFF Can someone explain this? Thanks Bardonia Seems to be a poor translation from Japanese. Anyway, I've figured out how it works. - In the "Door position OFF/ON" the interior lights will turn on when any door is opened. This will be your normal setting. - In the "ON/OFF" position, the light is simply turned on or off by the switch, regardless of the door.
