HEXLOCK Posted September 13, 2007 Share Posted September 13, 2007 Just bought my lexus and the center caps on the wheels are making noise. How do i fix this. Yes, they are loose is there any way to tighten them up?? Also have a little bit of MPG issue just ran sea foam thru today. Going to clean out all of the air flow sensors tomorrow Any other pointers The O2 sensor if replaced. does it matter what kind i use? Dont give me only oem crap cause its a generic sensor Quote Link to comment Share on other sites More sharing options...
SnesleyWipes Posted September 13, 2007 Share Posted September 13, 2007 Just bought my lexus and the center caps on the wheels are making noise. How do i fix this. Yes, they are loose is there any way to tighten them up??Also have a little bit of MPG issue just ran sea foam thru today. Going to clean out all of the air flow sensors tomorrow Any other pointers The O2 sensor if replaced. does it matter what kind i use? Dont give me only oem crap cause its a generic sensor OK, take them off...then just add enough pressure outward to each prong (tab) to move them ~1mm all the way around. This will ensure a tighter fit on your wheel. If the cap is hard to snap back in, make sure the prongs are directed to the center and punch it in. You will have no more noise. Quote Link to comment Share on other sites More sharing options...
