DAZZX Posted September 5, 2007 Share Posted September 5, 2007 OK TO GET THE MIDDLE BOLT. HERE IS WHAT YOU NEED TO DO. GET SOME LIQUID WRENCH, SOME LEATHER , DUCK TAPE AND SOME GREASE. NOW WRAP THE LEATHER AROUND YOUR FOREARM WITH DUCKTAPE. NOW GREASE UP THE LEATHER FRONT AND BACK(HANDS INCLUDED) REAL GOOD . THEN GRAB A 19 MM SOCKET. WRAP IT TO YOUR PALM WITH THE DUCK TAPE.OH SPRAY THE LIQUID WRENCH FIRST ON THE EGR VALVE. LET IT RUN DOWN THE VALVE ONTO THE CLAMP AND BOLT.SPRAY A LOT. GRAB YOUR 12MM WRENCH AND PUT IT ON THE BOLT BOX END. NOW BANG THE HELL OUT OF IT.THE BOT WILL BREAK FREE. YOUR HOME SWEET HOME AFTER THAT. OH AND YOU CAN GET THE BOTTOM 2 BOLTS WITH SOME LIQUID WRENCH ALSO. I HAD TO REMOVE THE THROTTLE CABLE BRACKET ALSO.THE TOP 2 BOLTS ARE EASY. NOW HAVE YOUR SELF A BEER. YOU JUST SAVED 400 DOLLARS ON LABOR. Quote Link to comment Share on other sites More sharing options...
landar Posted September 7, 2007 Share Posted September 7, 2007 NOW HAVE YOUR SELF A BEER. YOU JUST SAVED 400 DOLLARS ON LABOR. Thanks, DAZZX! What kinda beer?? Quote Link to comment Share on other sites More sharing options...
mejojo Posted September 14, 2007 Share Posted September 14, 2007 OK TO GET THE MIDDLE BOLT. HERE IS WHAT YOU NEED TO DO. GET SOME LIQUID WRENCH, SOME LEATHER , DUCK TAPE AND SOME GREASE. NOW WRAP THE LEATHER AROUND YOUR FOREARM WITH DUCKTAPE. NOW GREASE UP THE LEATHER FRONT AND BACK(HANDS INCLUDED) REAL GOOD . THEN GRAB A 19 MM SOCKET. WRAP IT TO YOUR PALM WITH THE DUCK TAPE.OH SPRAY THE LIQUID WRENCH FIRST ON THE EGR VALVE. LET IT RUN DOWN THE VALVE ONTO THE CLAMP AND BOLT.SPRAY A LOT. GRAB YOUR 12MM WRENCH AND PUT IT ON THE BOLT BOX END. NOW BANG THE HELL OUT OF IT.THE BOT WILL BREAK FREE. YOUR HOME SWEET HOME AFTER THAT. OH AND YOU CAN GET THE BOTTOM 2 BOLTS WITH SOME LIQUID WRENCH ALSO. I HAD TO REMOVE THE THROTTLE CABLE BRACKET ALSO.THE TOP 2 BOLTS ARE EASY. NOW HAVE YOUR SELF A BEER. YOU JUST SAVED 400 DOLLARS ON LABOR. Please post a picture of THAT arrangement! Joe Quote Link to comment Share on other sites More sharing options...
