Transmission Problems
I was waiting for the green light and then step on the gas pedal. The car would not go forward. Turned it off and wait for about 2 minutes. Turned it back on and the check engine and trac off came on. The car was able to drive slowly, but wouldn't change gear. It is also making so whimming noise inside the transmission.
I scanned for codes and got these: 753, 758, 765, 1760. They all indicating a transmission solenoid
753: shift solenoid A electrical
758: shift solenoid B electrical
765: shift solenoid D malfunction
1760: don't know what this code is
I am wondering if the solenoid is having a problem or the entire transmission is having a problem. What do you guys think?
Thank you!
  • 5 months later...
Thank you!
I am having the same problem did you find a fix?
  • 7 months later...
Thank you!
Bump, i am also having the same problems. Anyone have any insight?
