basao Posted August 25, 2007 Share Posted August 25, 2007 I hope you ES veterans out there don't find this too elementary but I need some general direction on how to replace the rear left turn signal light bulb on my 96 ES300. I've replaced head light bulbs before but this looks totally different. Do I remove the entire left rear assembly to change the bulb or am I not seeing something really simple? Thanks in advance for your assistance. Quote Link to comment Share on other sites More sharing options...
CUMan Posted August 26, 2007 Share Posted August 26, 2007 Yeah, you have to remove the entire taillight assembly. Your first step is to remove the black plastic trim piece that runs across the top rim of the trunk. Just pull up on it. There are several clips which hold it in place. Then remove the clips which hold the trunk liner in place. Push the trunk liner away from the taillight assembly, and you will see numerous bolts and nuts that hold the assembly in place. I don't recall the exact number of bolts, but there are probably four or five that have to be removed. There are also a number of protruding bolts which do not have to be removed. If I recall correctly, I think the nuts you need to remove are 10 mm. You will find these easier to remove if you use a deep well socket. There is one bolt over in the far corner that is easy to overlook. When you have all the nuts removed, pull out on the assembly. Get it far enough from the car body to give you access to the bulbholders. While you are at it, replace all the bulbs in the assembly. You don't want to go through this every time a bulb goes out. Quote Link to comment Share on other sites More sharing options...
Lexucan Posted August 26, 2007 Share Posted August 26, 2007 Here's a previous thread about replacing the taillight bulbs with nice pics and everything! http://us.lexusownersclub.com/forums/index...showtopic=15005 Quote Link to comment Share on other sites More sharing options...
basao Posted August 28, 2007 Author Share Posted August 28, 2007 I hope you ES veterans out there don't find this too elementary but I need some general direction on how to replace the rear left turn signal light bulb on my 96 ES300. I've replaced head light bulbs before but this looks totally different. Do I remove the entire left rear assembly to change the bulb or am I not seeing something really simple? Thanks in advance for your assistance. Quote Link to comment Share on other sites More sharing options...
basao Posted August 28, 2007 Author Share Posted August 28, 2007 I am soooo soooory. As you can see, I'm really a newbie. I thank you very much for your assistance and will surely be more knowledgable next time. This forum is great. I'll be returning for sure. Mahalo (Thank You) from Hawaii! Quote Link to comment Share on other sites More sharing options...
sk1951 Posted December 12, 2009 Share Posted December 12, 2009 Here's a previous thread about replacing the taillight bulbs with nice pics and everything! http://us.lexusownersclub.com/forums/index...showtopic=15005 So way cool! Thank you Lexucan and a really special thanks to DKRC-2003 (I sent a PM message to him). Feel sorry for the 1156 screw up. Never force a bulb or a square peg...so to speak. Wonder how that turned out? Quote Link to comment Share on other sites More sharing options...
