Mark460 Posted August 16, 2007 Share Posted August 16, 2007 Occasionally the engine will not idle. I can hold the gas pedal and increase RPM and it runs fine and I can get it on the road and drive the car fine, but if I let off the gas it dies immediately. After driving for a while, it clears up and idles fine. Then it may work great for days, starts up cold fine and idles immediately, and then one day it will act up again. Is there an idle air control motor sticking? thanks Mark Quote Link to comment Share on other sites More sharing options...
LexusGS400RacerX Posted August 24, 2007 Share Posted August 24, 2007 Are all of your oils filled necessarily? Sometimes if they run out, the car can stop running on Idle. If anything, check with your local garage. Quote Link to comment Share on other sites More sharing options...
