LexLootha Posted August 6, 2007 Share Posted August 6, 2007 I just bought a certified pre-owned 2002 Lexus ES300. I love the car...however within the first few weeks I made a list of things I found wrong with the car for service to take care of which they did and it was completely covered under the warranty. I have a 3 year warranty and I want to make sure I have them replace as much as I can before my warranty runs out. If everybody that has had a 2002 or similar model year can tell me things to look out for I would greatly appreciate it. Quote Link to comment Share on other sites More sharing options...
Firewalker Posted August 6, 2007 Share Posted August 6, 2007 I just bought a certified pre-owned 2002 Lexus ES300. I love the car...however within the first few weeks I made a list of things I found wrong with the car for service to take care of which they did and it was completely covered under the warranty. I have a 3 year warranty and I want to make sure I have them replace as much as I can before my warranty runs out. If everybody that has had a 2002 or similar model year can tell me things to look out for I would greatly appreciate it. if your getting any pulsating during braking have them replace your rotors. There was a TSB issued for that problem. Quote Link to comment Share on other sites More sharing options...
steviej Posted August 10, 2007 Share Posted August 10, 2007 1. the 2002 ES had an annoying rattle/noise caused by improper fitting of the insulation in the rear doors. There is a TSB about that. They either resecure or remove the insulation. Noise gone. 2. The previously mentioned brake pad/rotor metal mismatch TSB from 2003. How many miles on the new ride? If your brakes have already been changed, then my guess is that they won't honor this TSB. 3. The infamous tranny "lag in shifting" TSB. I refer you to the 45 some odd page thread pinned at the top of this subforum. Find out the software verison you have in your car now. Consider upgrading if you exerience the original symptoms. There were two software verisons, the best of the two is the latest one from April 2005. Please read/scan the pinned thread first before asking questions. 4. If the moonroof is noisy in that it creaks when you go over small bumps, have the gasket replaced. There was a TSB on that too. Here is the www.alldata.com list of TSBs: (I have put the ones mentioned in bold) Automotive Recall and Technical Service Bulletin Titles for 2002 Lexus ES 300 V6-3.0L (1MZ-FE). TSB Number & Issue Date TSB Title SSC1LG DEC 01 Recall - Driver's Air Bag Replacement SSC1LF DEC 01 Recall - L/H Front Brake Tube Inspection/Replacement TSB Number & Issue Date TSB Title PG001R-06 NOV 06 Battery Maintenance for In-Stock Vehicles BR003R-04 SEP 06 Brakes - Disc Brake Component Identification EL010-06 SEP 06 Body - Rear Power Window(s) Inoperative BR002R-02 AUG 06 Brakes - Front Brakes Vibrate AU001-06 APR 06 Audio System - Quick Reference Troubleshooting Guide ST004R-01 APR 06 Steering - Vehicle Pulls To One Side Manual Supplement SS003-05 NOV 05 Audio System - CD Player Skip Verification BO012-05 NOV 05 Interior/SRS - Seat Cover Replacement Recommendations SS002R-01 AUG 05 Antitheft System - Immobilizer Key Code Reset BO004-05 JUL 05 Wipers/Washers - Wiper Blade Cleaning/Maintenance EL009-05 JUN 05 A/C - Inoperative/A/C Light Flashing TC004R-03 APR 05 Engine/Transmission Controls - Poor A/T Shift Quality EG007-05 MAR 05 Cooling System - Radiator Cap Inspection Procedure PA001-05 JAN 05 Paint - Iron Rust Contamination Repair BO012-04 DEC 04 Interior - Console Lid Lock Opener Improvement TC002R-03 DEC 04 Engine Controls - ECM Memory Reset After A/T Service AC005-04 DEC 04 A/C - Sensor Inspection Procedures NV005-04 MAY 04 Body - Rattles/Squeaks From Moonroof EG005-04 MAY 04 Exhaust System - Excessive Sulfur Dioxide Odors NV004-04 MAY 04 Interior - Rear Door Trim Panel/Seal Rattles TC003-04 APR 04 A/T -Transmission Solenoid Identification BO003-04 FEB 04 Interior - Rear Package Tray/Sunshade Binding NV001-04 JAN 04 Body - Rattle/Tick Noise From Base of Windshield SS002-03 DEC 03 Engine Controls - O2 Sensor Monitor Threshold Values BO012-03 DEC 03 Interior - Seat Belt Extender Applications/Availability EL014-03 NOV 03 Charging System - Low Battery/No Start Condition NV011-03 OCT 03 Body/Interior - Rear Seat/Parcel Tray Area Rattles BO009-03 OCT 03 Body - Window Regulator Deformation SS001R-01 SEP 03 Engine Controls - ECU Programming Procedure BO007-03 SEP 03 Interior - Trim Panel Removel/Installation Precautions TC004-03R AUG 03 A/T - Poor Shift Quality EG001R-02 JUN 03 Engine Controls - MIL ON/Multiple DTC's Set EL004-03 MAY 03 Instruments - Mirror Compass Recalibration Process BO003-03 MAY 03 Interior - Seat Back Board Cover Comes Loose CRIB127 MAY 03 Glass - Windshield and Fixed Glass Bonding NV004-03 APR 03 Body - Creak/Snap/Rattle From Top of Windshield EG001-03 FEB 03 Exhaust System - Sulfur Smell CRIB122 FEB 03 Body - Body Sectioning EL001R-03 JAN 03 Instruments - Difficulty Reading in Direct Sunlight PG012-02 OCT 02 Suspension - Ball Joint Inspection Method BO005-02 SEP 02 Interior - Seat Belt Extender Availability/Applications EG003R-02 SEP 02 Fuel System - Gas Cap Sticking SU006-02 AUG 02 Suspension - Front Coil Spring Creaking Noise NV001R-02 AUG 02 Exhaust System - Heat Shield Rattles EL010-02 AUG 02 Navigation System - Identification Method/DVD Map Data CRIB121 AUG 02 Body - Door and Moonroof Disassembly Precautions CRIB120 AUG 02 Paint - Paint Codes - All EL008-02 JUL 02 Steering -Tilt Wheel Hard To Move From Down Position AU003-02 JUL 02 Audio System - Radio Faceplate Removal Clarification TC002-02 JUN 02 A/T - Harsh 2nd to 3rd Gear Shift at High Altitude TC001-02 MAY 02 A/T - Fluid Requirements AU002-02 APR 02 Audio - No Sound From Amplifier PG004-02 MAR 02 Engine Cooling - New Pink Coolant SS001-02 MAR 02 Drive Shaft - Tool: Nut Chisel AU001-02 FEB 02 Audio System Amplifier - Installation Cautions EG002-02 FEB 02 OBD II - Readiness Monitor Drive Patterns NV001-02 JAN 02 Catalytic Converter - Heat Shield Rattle PG002-02 JAN 02 Certification Label - Replacement Availability PG001-02 JAN 02 Corrections Index - Repair Manual PG003-02 JAN 02 VIN Plate - Replacement Availability SS011-01 DEC 01 Airbag Deployment Wire - Sub Harness NV010-01 DEC 01 Body/Interior - Squeaks and Rattles NV003-02 NOV 01 Interior - Rear Door Trim Panel Rattles AC002-01 NOV 01 A/C - Compressor Shaft Seal Repair Procedure BO001R-01 NOV 01 Seat Belts - Extender Availability Update CRIB115 NOV 01 Air Bag - Repair Precautions SS007-01 OCT 01 Tools - Customization Feature For Diagnostic Tester ST002-01 SEP 01 Steering Wheel - Off Center Adjustment Procedure CRIB114 SEP 01 Paint - Paint Codes PG023-01 AUG 01 Moof Roof - Initialization PG025-01 AUG 01 Compass - Initial Calibration During PDS I hope this helps, steviej Quote Link to comment Share on other sites More sharing options...
LexLootha Posted August 20, 2007 Author Share Posted August 20, 2007 Thanks Steve, I really appreciate that. Quote Link to comment Share on other sites More sharing options...
LexLootha Posted August 20, 2007 Author Share Posted August 20, 2007 HA! That was one of the first things I had them replace....thanks for the heads up though! Quote Link to comment Share on other sites More sharing options...
