Long story short, I damaged the 60 amp fusible link for my ABS power supply. Has anyone replaced a fusible link in the fuse box and can provide some advice/help. I've added a picture to show where it is located.
thanks
I damaged a fusible link on my 1990 LS400 once.
And I had to disconnect the battery, loosen something to get under the fuse box, then loosen 2 bolts that hold the fusible link.
The amperage of the link can be found on the fuse box, or the inside of it.
Then I brought the link to a local Toyota dealer to buy a replacement with the same amperage.
On my 1999 RX300, I've never got same problem, so I just hope this info would help in some way.
Good luck.
