1995 ES300 Posted June 24, 2007 Share Posted June 24, 2007 I have a 95 ES300 and the cd changer will not eject the cartridge, not sure what is wrong but I would love any help and suggestions!! Quote Link to comment Share on other sites More sharing options...
gbhrps Posted June 27, 2007 Share Posted June 27, 2007 Assuming that the changer unit still works and will play and change CD's( its a trunk mounted unit?), the problem could be in the ejection switch (its dirty and might be cleaned up with electronic contact spray (get it from Radio Shack), or it could be that you have a broken drive belt that operates the ejection system, or a stripped gear on its gear drive, a burnt motor, or a jammed system with a CD not properly back in its cassette. Removing the entire unit from the car and opening the case up is the only way to find out for sure, and even then it may be beyond you to narrow down the problem and an audio repair shop may be your only solution. Who knows, a look at eBay may get you another unit cheaply, and then you can break the old unit open to get you CD's. Good Luck! Quote Link to comment Share on other sites More sharing options...
