Shayan Posted June 18, 2007 Share Posted June 18, 2007 Hey guys, My question is that i recently got a used compressor put on and it was good for a week and now it blows hot air. Come to find out i have a leak. Where is the common place these cars leak from? thanks in advance, Shayan G. Quote Link to comment Share on other sites More sharing options...
homemechanic Posted June 18, 2007 Share Posted June 18, 2007 Hey guys,My question is that i recently got a used compressor put on and it was good for a week and now it blows hot air. Come to find out i have a leak. Where is the common place these cars leak from? thanks in advance, Shayan G. You can spot the leak by looking at the system and follow the lines. If you see an oil substance on a spot, that's probably the leak. It is because oil is also added to the freon. When freon leaks out, the oil will leak too. If you didn't add oil into the used compressor after you installed it, I am not sure how to spot the leak. Quote Link to comment Share on other sites More sharing options...
Shayan Posted June 18, 2007 Author Share Posted June 18, 2007 part of my condensor close to the gasket has a oil like gunk around it. I was thinking it was there. thanks alot. Quote Link to comment Share on other sites More sharing options...
