Service This Th. What Tsibs Ask To Address
Hello all,
I'll have service for my ES330 this Thursday.
My main complain is about hectic transmission at lower speed.
What else I should ask Lexus tech to address before my 50k/4 years warranty runs out?
Any TSIB list for ES330? Lexus tech will not tell me unless I point directly :chairshot:
Thanks.
www.alldata.com
Automotive Recall and Technical Service Bulletin Titles for:
2004 Lexus ES 330 V6-3.3L (3MZ-FE).
TSB Number & Issue Date TSB Title
SSC4LI DEC 04 Recall - Seat Belt Status Switch Replacement
LSC4LG NOV 04 Campaign - Navigation System DVD Update
NV005-06 DEC 06 Body - Upper/Lower Windshield Ticking Noise
PG001R-06 NOV 06 Battery Maintenance for In-Stock Vehicles
EL010-06 SEP 06 Body - Rear Power Window(s) Inoperative
BO005R-06 SEP 06 Keyless Entry - Transmitter Key Casing Availability
PA003-03 JUL 06 Paint - 2004 Year Model OEM Paint Codes
NV001-06 MAY 06 Interior - Front Seat Squeaking Noise
AU001-06 APR 06 Audio System - Quick Reference Troubleshooting Guide
ST004R-01 APR 06 Steering - Vehicle Pulls To One Side Manual Supplement
BO009R-04 DEC 05 Restraints - Seat Belt Extender Availability/Application
SS003-05 NOV 05 Audio System - CD Player Skip Verification
BO012-05 NOV 05 Interior/SRS - Seat Cover Replacement Recommendations
SS005R-01 AUG 05 Antitheft - Diagnostic Tester Immobilizer Function
BO004-05 JUL 05 Wipers/Washers - Wiper Blade Cleaning/Maintenance
EL009-05 JUN 05 A/C - Inoperative/A/C Light Flashing
EG012R-04 JUN 05 Engine Controls - Entering VIN After PCM Replacement
EL007-05 MAY 05 SRS - SRS/Passenger Air Bag OFF Lamps Stay ON/DTC B1785
ST001-05 APR 05 Steering - Clunk/Pop/Knock Noise Turning
TC004R-03 APR 05 Engine/Transmission Controls - Poor A/T Shift Quality
EG007-05 MAR 05 Cooling System - Radiator Cap Inspection Procedure
EG006-05 MAR 05 Engine Controls - MIL ON/DTC P0346 Set
EL002-05 FEB 05 Restraints - Passenger Air Bag Lamp ON
EG003-05 FEB 05 Engine Controls - MIL ON/O2 Sensor DTC's Set
PA001-05 JAN 05 Paint - Iron Rust Contamination Repair
EG008R-04 JAN 05 Emissions - LEVII EVAP System Check For Multiple DTC's
BO012-04 DEC 04 Interior - Console Lid Lock Opener Improvement
AC005-04 DEC 04 A/C - Sensor Inspection Procedures
ST003R-04 DEC 04 Steering/Suspension - Vehicle Pull or Drift
EG011-04 OCT 04 Engine - Main Bearing Journal Diameter Stamping Revision
CRIB141 OCT 04 Paint - Chip Resistant Coatings
NV006-04 SEP 04 Interior - Squeaking Noise From Seat Track Area
EL007R-03 MAY 04 SRS - Occupant Sensor DTC's B1150 and B1650
NV004-04 MAY 04 Interior - Rear Door Trim Panel/Seal Rattles
TC003-04 APR 04 A/T -Transmission Solenoid Identification
PA001-04 APR 04 Paint - Color, Scratch Resistant & Anti-Acid Paint
BR001-04 MAR 04 Brakes/Traction Control - 'Zero Point Calibration'
ST003-04 FEB 04 Steering/Suspension - Vehicle Pulls to The Left
EL007R-03 DEC 03 SRS - Calibration of Occupancy Classification System
BO012-03 DEC 03 Interior - Seat Belt Extender Applications/Availability
NV011-03 OCT 03 Body/Interior - Rear Seat/Parcel Tray Area Rattles
SS003R-01 SEP 03 Engine Controls - ECU Programming Error Displayed
PA003-03 JUL 03 Paint - Paint Colors - All
I hope this helps.
steviej
www.alldata.com
I hope this helps.
steviej
thanks a lot :cheers:
