Stroker 2GR FE
Can the 2GR FE shortblock be replaced with
a 1GR FE shortblock ?
Certainly is a nice way to have a 'Stroked'
2GR FE if so -
Are there any 2GR FE / 1GR FE Engine apart
.jpgs posted anywhere yet ?
Would like to see:
the con rods / pistons of both engines
outside and inside of a 1GR FE cyl. Block
the heads / intake internals for a 2GR FE
and 1GR FE
are these 6 bolt main blocks ?
1GR :unsure: 2GR
  • 9 months later...
Stroker 2GR FE
2GR FE if so -
Would like to see:
and 1GR FE
1GR :unsure: 2GR
The 1GR-FE block is definatelt different than the FWD 2GR-FE block. I do not know about the 2GR-FSE rear wheel drive block. I am guessing that the internals might be swappable between the rwd motors but not to the fwd motor. My reason for this guess is the flywheel bolt circle is much larger in the 1GR than the fwd 2GR. the tranny mounitng circle is so loarge on the 1GR that the fwd 2GR tranny will not bolt to it even with an adapter, as the axle will not clear the 1GR block. ( from my attempts to mate a solara E series tranny to a tacoma 1GR)
I would love to get my hands on a 2GR and compare some differences.. if i could get the internals from the 1gr into the 2ggr fwd block i could make a fwd 4.0 v6 that i could then fit in the back of my MR2. As it is, there is no tranny option that will work with the 1GR set up transversely. All of this is contrary to the popular but wrong info floating around that all GR blocks are the same.
