btexprs Posted May 30, 2007 Share Posted May 30, 2007 Recently, I got an oil change performed on my 2006 GS300 and I did not use the Lexus dealer. I now need to reset the "oil maintenance required" message that displays on the dashboard. Does anyone have the instructions to do that? Quote Link to comment Share on other sites More sharing options...
boB_2006_GS300 Posted May 31, 2007 Share Posted May 31, 2007 Recently, I got an oil change performed on my 2006 GS300 and I did not use the Lexus dealer. I now need to reset the "oil maintenance required" message that displays on the dashboard. Does anyone have the instructions to do that? from Clublexus: Are you getting the OIL MAINT RESET message? If so, here's how to get rid of it: 1. Push the “ODO TRIP” switch in the switch box to change the display to blank. 2. Turn the engine switch off. 3. Turn the engine switch on with the trip meter “RESET” switch held down. 4. Keep pushing the “RESET” switch for longer than 7 seconds after the engine switch is turned on. After the above operation, the master warning light comes on, a warning tone sounds and the above message appears to inform you that the engine oil maintenance data has been reset. Although I got my oil change today, on schedule, I was annoyed that a RED warning light stayed on. I did the steps above over the weekend to get rid of the warning.... AND IT WORKS! :) Quote Link to comment Share on other sites More sharing options...
Burgundy GS300 Posted July 26, 2007 Share Posted July 26, 2007 Recently, I got an oil change performed on my 2006 GS300 and I did not use the Lexus dealer. I now need to reset the "oil maintenance required" message that displays on the dashboard. Does anyone have the instructions to do that? from Clublexus: Are you getting the OIL MAINT RESET message? If so, here's how to get rid of it: 1. Push the “ODO TRIP” switch in the switch box to change the display to blank. 2. Turn the engine switch off. 3. Turn the engine switch on with the trip meter “RESET” switch held down. 4. Keep pushing the “RESET” switch for longer than 7 seconds after the engine switch is turned on. After the above operation, the master warning light comes on, a warning tone sounds and the above message appears to inform you that the engine oil maintenance data has been reset. Although I got my oil change today, on schedule, I was annoyed that a RED warning light stayed on. I did the steps above over the weekend to get rid of the warning.... AND IT WORKS! :) I have my Service Engine Light on.... is their a procedure like this to reset the ECU and see if it will dissapear for the future? thank you Quote Link to comment Share on other sites More sharing options...
simplyadditions Posted May 7, 2011 Share Posted May 7, 2011 Recently, I got an oil change performed on my 2006 GS300 and I did not use the Lexus dealer. I now need to reset the "oil maintenance required" message that displays on the dashboard. Does anyone have the instructions to do that? Same thing happened to me! Quote Link to comment Share on other sites More sharing options...
Ghost of LEXUS Posted May 16, 2011 Share Posted May 16, 2011 Recently, I got an oil change performed on my 2006 GS300 and I did not use the Lexus dealer. I now need to reset the "oil maintenance required" message that displays on the dashboard. Does anyone have the instructions to do that? from Clublexus: Are you getting the OIL MAINT RESET message? If so, here's how to get rid of it: 1. Push the “ODO TRIP” switch in the switch box to change the display to blank. 2. Turn the engine switch off. 3. Turn the engine switch on with the trip meter “RESET” switch held down. 4. Keep pushing the “RESET” switch for longer than 7 seconds after the engine switch is turned on. After the above operation, the master warning light comes on, a warning tone sounds and the above message appears to inform you that the engine oil maintenance data has been reset. Although I got my oil change today, on schedule, I was annoyed that a RED warning light stayed on. I did the steps above over the weekend to get rid of the warning.... AND IT WORKS! :) Many thanks for you .. is that for GS 430 also Thank you again Incidentally I have a new member to the forum Quote Link to comment Share on other sites More sharing options...
