Engine Temp. Guage Not Working.
My Engine Temp. Guage that is on the left side of my Dash is not working at all. My Car also has no power when I first start it Cold so I was thinking it must be running rich because it thinks the Temp. is so low. Is this a Coolant Temp. Switch problem or should I look for something else.
Yeah the CEl is lit up but the procedure to check the codes (meaning the paperclip in the diagnostic port) doesn't work for me. I did hook it up to a scanner recently and I got a code for o2 sensor 1 bank 1. I am about to replace all o2 and a/f sensors but I wanted to know if the Coolant Temp. Switch is the reason my temp guage doesn't rise pass Cold on my Instrument panel.
