Help!
My drivers power side window is not going up or down automatically (why) is this a fuse issue or something more extensive?
Help!
A "slight" depression or lift of the button will only move the window during that action. A firm and full depression/lift will activate the automatic function. Most likely the FULL travel function, switch contacts, of the switch has failed.
Help!
WWest..Thank you so much for your advice.
  • 1 year later...
Help!
My Lexus just developed thesame problem today. Other windows work except the Driver's...What was the problem and how was it fixed....
  • 3 weeks later...
Help!
My RX300 (2000) had intermittent problem on the front passenger side. It came up and down intermittently using either power switches (passenger/driver sides). After several tries even removed the window motor, I found that the problem was the power switch on the passenger side. i went to a Junk yard bought one for $50 and the problem was fixed.
  • 3 weeks later...
Help!
How did you fix it? Mine is doing the same thing....... :angry:
