Gs400 In The Snow
I would recomend to go to the dealer, express your concern, and have them SHOW you the traction control. If there is no snow out then have them take the car out (depending on where you are, they will have cars set aside for test drives that the THRASH on...at least here in Bellevue) and place the tires on different surfaces (ie gravel, dirt & pavement) turn the wheel and slam down the gas. The tires will make like a half turn, chirp letting you know it broke loose, then communicate between all four and not slide. Due to the fact that you have the wheels turned, the tires will all gradually change surfaces...I would not recomend doing this for kicks in your own ride...but that is what a dealership is for. If they won't show you...they must not have faith in Lexus and should not be selling them...go somewhere else.
