Is It Transmission Problem?
konquistador
Hi Guys? Need Help.
I was wondering why my RX-300 doesn't start immediately after i insert the Key, It makes some starting noise for 2-3 seconds and then starts. Does it have something to do with Transmission? Even after starting the gears wont shift smoothly from Drive to Reverse etc. Have to pull it hard to change. Please let me know the resolution. Would changing the Transmission Fluid(Toyota Type IV as suggested in forum) make it better.
Thanks,
Kon
Hi Guys? Need Help.
Thanks,
Kon
"..makes some starting noise..."
Noise of engine turning over or sharp/rapid clicking sound...?
"..won't shift smoothly..." "have to pull it hard to change..."
There is no mechanical connection whatsoever from the shift level, shifter, to the transmission, transaxle, involved in drive to reverse, just electrical.
No transmission problems there, seemingly.
Hi Guys? Need Help.
Thanks,
Kon
Clicking sound would normally indicate poor battery connections or low battery. Clicking sounds and then start would most likely be poor/corroded connections.
