Engine Dies
mc teg
I need some help with this problem. Whenever I start my LS cold, it idles around 1300 in park and shakes around 900 in drive. When I am driving, it drives fine till you let off the gas. When you let off the gas, it starts surging around 400 rpm. When I am slowing down around 10 mph, the engine dies. I just replaced the fuel injectors about a month ago. Can this be fuel related or air related?
high idle is normal, try waiting until engine warmes up coomletely and then drive.
check if there are any differeces, when you see that the engine is about to stall, rev the engine up to 4-5k rpms and see if that helps.
let me know the result:)
