Clicking Noise From Engine / Ac
I have a 98 ES 300 w/ 145,000 miles and I have two problems:
1. Engine makes a clicking noise which gets faster when I push on the pedal but sometimes goes away after driving a long period of time.
2. As soon as I turn on the AC switch (not air, but AC switch) it makes a loud buzzing sound.
Any suggestions on what those two problems may be?
P.S. A friend told me that it could be the lifters/valves that need replacing, but I can't afford $1,000 right now... Are there any other solutions?
Thanks!
Thanks!
Does the noise goes away when the A/C is off? If so, then it seems that A/C compressor is about to go. If the noise is there with the A/C off, then it might be the alternator or power steering pump.
