Spark Plug Questions
What is the spark plug torque specification?
Also, besides the top engine cover and the front timing belt cover, which items need to be removed to access the center spark plugs? Looks like a large portion of the fuel injection air intake needs tobe removed.
18 N-m, 13 lb-ft TQ
The air intake duct and throttle body must be removed. (good time to
clean the throttlebody while it's off)
HTH
mike
18 N-m, 13 lb-ft TQ
HTH
mike
I'll be doing this soon on a 2001 GS300, any gaskets involved to R&R the throttlebody? Is spraying throttlebody with Gumout good enough?
Gaskets are reusable if not damaged
Use throttlebody cleaner if possible, some regular carb-cleaners can
damage modern EFI sensors/plastics or leave residue that can corrupt
Oxygen sensors..
mike
