127RX Posted August 25, 2003 Share Posted August 25, 2003 Hello all, just got a 2000 RX and wanted to change out the yellowish bulbs from the headlight assembly. any hints as to how to remove the assemblies so i can get to the 5W bulbs on the outer part of each unit? Thanks. Quote Link to comment Share on other sites More sharing options...
JonsRX300 Posted September 1, 2003 Share Posted September 1, 2003 To change the frosted light bulb, I went thru the wheel well, turned the wheel to the side and removed the screws holding the fender shroud in place, reached behind it to the light base socket and swapped the bulb. I used a blue bulb and the light now looks a cool white, instead of the goofy looking yellow. Quote Link to comment Share on other sites More sharing options...
127RX Posted September 2, 2003 Author Share Posted September 2, 2003 Thanks, I'll give it a try. Btw, did you change out the DRL's too? Quote Link to comment Share on other sites More sharing options...
JonsRX300 Posted September 4, 2003 Share Posted September 4, 2003 I installed 5000k bulbs from a guy on ebay. Very happy with them, the blue light is almost identical to the HID lighting, not as bright, but the same color. Quote Link to comment Share on other sites More sharing options...
