robhurlburt Posted March 30, 2007 Share Posted March 30, 2007 I rebuilt my starter with the starter rebuild kit last october because i was having slight starting issues. Ticking, not correctly turning over. Everything seemed to be working good, but now sometimes it will turn over for 25 to 30 seconds before it finally starts. It used to be one or two cranks of the engine and i would be golden. Any ideas? The car turns over fine, has plenty of power, new battery (october), and sometimes it will catch for a half second, then continue turning over. Thanks for your help! Quote Link to comment Share on other sites More sharing options...
robhurlburt Posted April 3, 2007 Author Share Posted April 3, 2007 I rebuilt my starter with the starter rebuild kit last october because i was having slight starting issues. Ticking, not correctly turning over. Everything seemed to be working good, but now sometimes it will turn over for 25 to 30 seconds before it finally starts. It used to be one or two cranks of the engine and i would be golden. Any ideas? The car turns over fine, has plenty of power, new battery (october), and sometimes it will catch for a half second, then continue turning over. Thanks for your help! nobody has any ideas? Quote Link to comment Share on other sites More sharing options...
92Lex Posted April 5, 2007 Share Posted April 5, 2007 Is it always like this, regardless of engine temperature? Quote Link to comment Share on other sites More sharing options...
robhurlburt Posted April 5, 2007 Author Share Posted April 5, 2007 Is it always like this, regardless of engine temperature? yes Quote Link to comment Share on other sites More sharing options...
92Lex Posted April 8, 2007 Share Posted April 8, 2007 Check the "cranking" fuel pressure. Quote Link to comment Share on other sites More sharing options...
robhurlburt Posted April 9, 2007 Author Share Posted April 9, 2007 Check the "cranking" fuel pressure. how do i do that? Quote Link to comment Share on other sites More sharing options...
92Lex Posted April 11, 2007 Share Posted April 11, 2007 Save yourself some money and have it professionally diagnosed. It's probably going to cost you more to buy a fuel pressure gauge than it would to have it diagnosed. Quote Link to comment Share on other sites More sharing options...
Mr Bill Posted April 15, 2007 Share Posted April 15, 2007 SOme sort of idle valve sticks when the car is cold which may cause this - try giving it a little gas while cranking. If this is the problem, engine will die when you let off the gas. It only takes a couple of minutes for the engine to warm up where it will keep running. Had this problem on mine for a couple of years - happens intermittently.... there is a fix on this site somewhere..... Quote Link to comment Share on other sites More sharing options...
