Battery Cables
ok here's the deal i have a 94 ES300 and i would like to put an optima yellow top but the standard one as it will come out cheaper for me. Although as the issue is their too short to reach all the way to be in the right place :chairshot: . So what would help would be
1. What gauge cable should i use and where can i get it done
2. Should i replace the whole wiring to the battery to (relay?) and alt
3. Other alternatives to extending te cables
i plan to get the ground cable replaced anyway
The yellow top is a deep cycle battery, not a car starter battery. The yellow is a good choise for a second trunk battery if you run a amp with the car shut off for extended periods
