Medessa Posted January 17, 2007 Share Posted January 17, 2007 Have 1994 LS 400 with electronic air suspension. Both the left front and left rear have gone out. Lexus dealer quotes $1300+ for left front only. Does anyone know of conversion kits that will work or any more feasible solution for repair? Quote Link to comment Share on other sites More sharing options...
bsouth123 Posted January 17, 2007 Share Posted January 17, 2007 Have 1994 LS 400 with electronic air suspension. Both the left front and left rear have gone out. Lexus dealer quotes $1300+ for left front only. Does anyone know of conversion kits that will work or any more feasible solution for repair? Just sent you an email. I used http://www.arnottindustries.com/ Works great! Quote Link to comment Share on other sites More sharing options...
DanW Posted January 18, 2007 Share Posted January 18, 2007 Have 1994 LS 400 with electronic air suspension. Both the left front and left rear have gone out. Lexus dealer quotes $1300+ for left front only. Does anyone know of conversion kits that will work or any more feasible solution for repair? I also used Arnott Industries. I wish I hadn't. The back rides much too low, they are extrememly sensitive to cold, and initially 2 of the ones they sent me were defective. One (rear) was too soft and bottomed out constantly, and the other (front) was not assembled right and the lower bushing would not line up with the bolt where it connects to the lower control arm. Arnott did replace them, but the front replacement was still assembled wrong (althought it was a little closer!) I eventually got it adjusted at my own expense since I don't have time to keep sending them back and installing/uninstalling. There are some serious quality control problems with this product. Later they tried to tell me that both of the ones I sent back 'tested out ok'...which is possible and goes back to the issue of quality control and what is considered acceptable to them. Search the forum and you'll find others that have used this product. My advice, pay the premium for some OEM coil overs and stay away from this cheap stuff. I'll probably rebuild the OEM ones someday and throw these in the trash. Quote Link to comment Share on other sites More sharing options...
91LS400vgb Posted January 18, 2007 Share Posted January 18, 2007 strutmasters.com is another source Quote Link to comment Share on other sites More sharing options...
