Lexus876 Posted December 31, 2006 Share Posted December 31, 2006 I need some help finding a sunroof seal for a 1997 Lexus ES300. I have already contacted the delaer and its about $500 becuase it comes with the glass as well. If possibly anyone know where I can get just the seal or anyplace cheaper than $500? Any help is appreciated ebcuase I found out I need a new one after water leake dinto my car :( and yes the sunroof was closed all the way becuase I checked that. Thanks so much bye! Quote Link to comment Share on other sites More sharing options...
Toysrme Posted December 31, 2006 Share Posted December 31, 2006 The sunroof seal is designed to leak. Inside the tract where you can't see, there is a drain hole in each corner that drains under the car. When the drains clog up, water spills over the tract into the car. Blow the holes out with 20-40psi of compressed air. You'll be fine. (Even if the seal is almost completely rotted away.) Quote Link to comment Share on other sites More sharing options...
