coleycoleman1906 Posted November 12, 2006 Share Posted November 12, 2006 i have a 97 es300 , i replaced the power steering belt, by going through the wheel well. i took a chance by lossening up a visible screw, it worked and slid relieving the tension.. i replaced yhe belt but cant get that screw to move again! was that the power steering thingy i moved, i pressed and pulled at everything. should i just tighten the screw "as is"? the belt seems tight, with little slack. Quick responses will be greatly appeciated, car is still apart, and i have curch tomorrow, the work monday, LOL. E-Z fix gone wrong! thanx in advance Quote Link to comment Share on other sites More sharing options...
Toysrme Posted November 12, 2006 Share Posted November 12, 2006 What you do is take a long object & use it as a lever against something strong (Say like a suspension arm). Loosen the adjustment bolt, lever some good tension on the powersteering pump to really pull it pretty good. Hold it in plce & tighten the bolt. It's alittlebit of a pain, but that's pretty much how you do it. Quote Link to comment Share on other sites More sharing options...
coleycoleman1906 Posted November 12, 2006 Author Share Posted November 12, 2006 i have a 97 es300 , i replaced the power steering belt, by going through the wheel well. i took a chance by lossening up a visible screw, it worked and slid relieving the tension.. i replaced yhe belt but cant get that screw to move again! was that the power steering thingy i moved, i pressed and pulled at everything. should i just tighten the screw "as is"? the belt seems tight, with little slack. Quick responses will be greatly appeciated, car is still apart, and i have curch tomorrow, the work monday, LOL. E-Z fix gone wrong! thanx in advance supposedly im on my back beneath the hub, head is towards the front of the car with a long object, with this leverage scenario, would i be pushing or pulling? or do i do it the other way, im going to do it at the crack of dawn! Thanks for responding so quickly, may god bless u!! meanig do i push it towards the bak of vehicle, or pull it towards the front? Quote Link to comment Share on other sites More sharing options...
