coleycoleman1906 Posted November 12, 2006 Share Posted November 12, 2006 Hello All, I have a 97 es300 and i have the front valve cover gasket off, im thinking about tackling the rear but I wanna know if i put the front back on today, and attempt the back tomorrow will i have to take the front off again?! Thanks in advance!? Quote Link to comment Share on other sites More sharing options...
coleycoleman1906 Posted November 12, 2006 Author Share Posted November 12, 2006 Hello All, I have a 97 es300 and i have the front valve cover gasket off, im thinking about tackling the rear but I wanna know if i put the front back on today, and attempt the back tomorrow will i have to take the front off again?! Thanks in advance!? another question, if I may, LOL, the spark plug rings, they dont fit in the holes of the valve cover! Do iwrap them around the spark plug housings or do I keep trying to pry them into the valve cover? does the opening of the rings face up or down?! Quote Link to comment Share on other sites More sharing options...
John Martin Posted November 14, 2006 Share Posted November 14, 2006 No, you should not have to remove the front. You will have to remove the front injector brackets to get the intake plenum -- not manifold -- off. Unless you got the wrong parts, the spark plug seals should fit. You will have to run a small wire or toothpick around the opening to get them to stretch over the spark plug tubes. JM Quote Link to comment Share on other sites More sharing options...
