Skippi Posted November 8, 2006 Share Posted November 8, 2006 I have used the search function and read many posts but still don't see the answer. I have a 96 ES300 it needs both outer CV boots replaced. I have the 6 hex bolt style shafts. I want to do this my self and believe in the Toyota rep for quality CV joints. I just am going to replace the boots. (using Toyota kits) I have read the Autozone replacement procedure I don't understand the separation of the axle from the transaxle. After I mark the flanges and take out the hex bolts. Doesn't the shaft come off the flange? The picture doesn't help and the article says "Remove the 6 hex head bolts from the driveshaft, then pry the assembly out. On the left side you will have to remove the bearing lock bolt and snap ring prior to removal." I would also like to know if popping the ball joint is the easiest way to get the lower susp. loose vs removing the control arm. Quote Link to comment Share on other sites More sharing options...
BrownCow Posted January 25, 2007 Share Posted January 25, 2007 As I'm sure you realize by now 3 mo later the Toyota remanufactured axle does not come with the hex head bolts but rather only as a single piece that extends into the transmission. I was disappointed to discover this today when arrived home. I guess this means I'll have to enter the tranny, but I can't see where or how to put the snap ring on the end of the inboard shaft. I would appreciate a voice of experience. Quote Link to comment Share on other sites More sharing options...
