LuckyApril7 Posted October 25, 2006 Posted October 25, 2006 My car makes a loud whirring noise in park every morning when i start it to warm it up . Then it shifts really hard out of park. All my other gears work fine. This only happens when i leave my car parked for awhile then start it up and it only happens out of Park. I have a 92 SC400 with 160K miles. Last tranny oil change was 2 months ago with Type 3 ATF.
LuckyApril7 Posted October 27, 2006 Author Posted October 27, 2006 why would you diagnose the trans throttle cable? Has this happened to anyone you know before?
jzz30 Posted October 27, 2006 Posted October 27, 2006 happened on my LS. cable broke in a semi open position and casued the trans to shift in to gears hard becasue the extra line pressure. if its no that some people have fixed the problem by changing the rubber coupling in the driveshaft i dont really know about that though.
Chase Croft Posted October 27, 2006 Posted October 27, 2006 same thing is happening to me so i would be interested in knowing as well good question luckyapril7
