John Martin Posted September 29, 2006 Share Posted September 29, 2006 I have somehow misplaced the the fuel injector wiring harness for the right hand (firewall) side of the 91-93 Lexus ES 300 3VZ-FE engine while I was replacing the valve cover gaskets. Need one ASAP. If you have one to sell, or know of any place I could get one, I would be most appreciative. Thanks, John Martin 404-745-4022 Quote Link to comment Share on other sites More sharing options...
mehullica Posted October 1, 2006 Share Posted October 1, 2006 It's part the entire engine harness. Are you sure it's not bolted down under the valve cover? Quote Link to comment Share on other sites More sharing options...
John Martin Posted October 3, 2006 Author Share Posted October 3, 2006 I am an idiot. When putting the rear main harness back on the studs in the confined space between the firewall and the engine, I folded the fuel injector harness underneath the main. I mistakenly thought that one of the connectors was for a separate assembly for the injector section. I need to stick to 70's Italian engines. JM Quote Link to comment Share on other sites More sharing options...
