shawnberry45 Posted September 28, 2006 Posted September 28, 2006 someone please help!!! sounds great on driver side...passenger..is really faint.... any ideas???? amp radio nav???? thanks! shawn
hawkshaw Posted September 29, 2006 Posted September 29, 2006 Well, if it's anything like my 2006 LS430 Mark Levinson with navigation, there is a "DSP" menu in which the system can be optimized for different seating positions within the car, including one setting which is specific for the driver only. There is also a "Sound" menu where balance, fade, treble, mid and bass, can be adjusted.
shawnberry45 Posted September 29, 2006 Author Posted September 29, 2006 Well, if it's anything like my 2006 LS430 Mark Levinson with navigation, there is a "DSP" menu in which the system can be optimized for different seating positions within the car, including one setting which is specific for the driver only. There is also a "Sound" menu where balance, fade, treble, mid and bass, can be adjusted. yea i tried that..when i fade to the right..its really really faint..then when i put towards the middle..the driver side..comes alive and sounds perfect
PIONEERSUBY Posted September 30, 2006 Posted September 30, 2006 Well, if it's anything like my 2006 LS430 Mark Levinson with navigation, there is a "DSP" menu in which the system can be optimized for different seating positions within the car, including one setting which is specific for the driver only. There is also a "Sound" menu where balance, fade, treble, mid and bass, can be adjusted. yea i tried that..when i fade to the right..its really really faint..then when i put towards the middle..the driver side..comes alive and sounds perfect possibilies . number one is the speaker is blown but you havent said whether the voice nav still works or is it faint also. if voice nav also faint then . number 2 the drivers door speaker gets signal from the amp to the nav computer amp in the trunk. there the voice nav amp inside the computer interupts and mutes the sound signal for voice communications. it could be stuck on mute. the only way to know for sure would be to switch the computer with a known working computer .
shawnberry45 Posted September 30, 2006 Author Posted September 30, 2006 yea i only get the nav voice on the drivers side...the side that works.. hmmm i guess i could try testing the speakers to see if they are blownn....but what are the odds of both front and back speakers blown... jesus...this is drving me nuts Well, if it's anything like my 2006 LS430 Mark Levinson with navigation, there is a "DSP" menu in which the system can be optimized for different seating positions within the car, including one setting which is specific for the driver only. There is also a "Sound" menu where balance, fade, treble, mid and bass, can be adjusted. yea i tried that..when i fade to the right..its really really faint..then when i put towards the middle..the driver side..comes alive and sounds perfect possibilies . number one is the speaker is blown but you havent said whether the voice nav still works or is it faint also. if voice nav also faint then . number 2 the drivers door speaker gets signal from the amp to the nav computer amp in the trunk. there the voice nav amp inside the computer interupts and mutes the sound signal for voice communications. it could be stuck on mute. the only way to know for sure would be to switch the computer with a known working computer .
PIONEERSUBY Posted September 30, 2006 Posted September 30, 2006 yea i only get the nav voice on the drivers side...the side that works.. hmmm i guess i could try testing the speakers to see if they are blownn....but what are the odds of both front and back speakers blown... jesus...this is drving me nuts Well, if it's anything like my 2006 LS430 Mark Levinson with navigation, there is a "DSP" menu in which the system can be optimized for different seating positions within the car, including one setting which is specific for the driver only. There is also a "Sound" menu where balance, fade, treble, mid and bass, can be adjusted. yea i tried that..when i fade to the right..its really really faint..then when i put towards the middle..the driver side..comes alive and sounds perfect possibilies . number one is the speaker is blown but you havent said whether the voice nav still works or is it faint also. if voice nav also faint then . number 2 the drivers door speaker gets signal from the amp to the nav computer amp in the trunk. there the voice nav amp inside the computer interupts and mutes the sound signal for voice communications. it could be stuck on mute. the only way to know for sure would be to switch the computer with a known working computer . it sounds like the amp is out on the right side.
shawnberry45 Posted October 2, 2006 Author Posted October 2, 2006 well weirdest thing happen today.. got in my car..and now all speakers work?????? is this an amp problem..or a loose wire somewere...so weird!!!
