SC NUT Posted August 24, 2006 Share Posted August 24, 2006 I have a new key that needs to be programmed for my SC430. Dealer wants to charge me $25! I have heard from a former dealer employee that there is a way to do this yourself. Does anyone know how this is done??? Maybe somewhat like you do for your garage door opener?? Thanks. Quote Link to comment Share on other sites More sharing options...
Z-Roc Posted December 3, 2006 Share Posted December 3, 2006 nope I would let the dealer do it Quote Link to comment Share on other sites More sharing options...
Marty Witt Posted December 16, 2006 Share Posted December 16, 2006 See attached. Good luck. Marty Key_Programming.pdf Quote Link to comment Share on other sites More sharing options...
SC NUT Posted December 16, 2006 Author Share Posted December 16, 2006 See attached. Good luck. Marty Thanks Marty - - I found another dealer who would do it for nothing while the State inspection was being done. But this should be useful info to have on the site for others. Stu Quote Link to comment Share on other sites More sharing options...
Kevin Smith Posted December 28, 2006 Share Posted December 28, 2006 Believe it or not my dealer here in NY did it for free too ! Most dealers will not charge you anuthing for this service. Kevin See attached. Good luck. Marty Thanks Marty - - I found another dealer who would do it for nothing while the State inspection was being done. But this should be useful info to have on the site for others. Stu Quote Link to comment Share on other sites More sharing options...
riquede Posted February 23, 2007 Share Posted February 23, 2007 Do you have the guide to program the new key to the ignition transponder? so that the car will start with the new key? Deric Believe it or not my dealer here in NY did it for free too ! Most dealers will not charge you anuthing for this service. Kevin See attached. Good luck. Marty Thanks Marty - - I found another dealer who would do it for nothing while the State inspection was being done. But this should be useful info to have on the site for others. Stu Quote Link to comment Share on other sites More sharing options...
SC430ENCORE Posted May 30, 2008 Share Posted May 30, 2008 Hey, if you all ready have a master key you can program up to 3 more keys. but its a two step process. first you have to program your key fob to lock and unlock your doors/truck. then you have to program the chip in the key to start your engine. Yes, you really can do this yourself. The following link is the very best fully detailed site i'll found to date for all lexus/toyota key/fob programing and best of all is 100% FREE :D I'am not sure how to post this link but here it is. just copy and paste to you address bar then ad it to your favs: www.toy-lex.com/programming Quote Link to comment Share on other sites More sharing options...
PearSC400 Posted June 5, 2008 Share Posted June 5, 2008 Hey, if you all ready have a master key you can program up to 3 more keys. but its a two step process. first you have to program your key fob to lock and unlock your doors/truck. then you have to program the chip in the key to start your engine. Yes, you really can do this yourself. The following link is the very best fully detailed site i'll found to date for all lexus/toyota key/fob programing and best of all is 100% FREE :D I'am not sure how to post this link but here it is. just copy and paste to you address bar then ad it to your favs: www.toy-lex.com/programming ++++++++++++++++++++++++++++++++++++++++ Anybody have any success in programming the transponder and remote for a '05 SC430? Does anybody know how many "keys" and remotes the system will accept? I've tried all the programming guides I can find (including the ones referenced in this thread) with no success. The closest I've found is the Tech Svc Bult EL005-01 (for the '01 and '02) whcih does appear to put the '05 into "ADD" mode for the remote but it will not "accept" the remote. Quote Link to comment Share on other sites More sharing options...
PearSC400 Posted June 5, 2008 Share Posted June 5, 2008 Hey, if you all ready have a master key you can program up to 3 more keys. but its a two step process. first you have to program your key fob to lock and unlock your doors/truck. then you have to program the chip in the key to start your engine. Yes, you really can do this yourself. The following link is the very best fully detailed site i'll found to date for all lexus/toyota key/fob programing and best of all is 100% FREE :D I'am not sure how to post this link but here it is. just copy and paste to you address bar then ad it to your favs: www.toy-lex.com/programming ++++++++++++++++++++++++++++++++++++++++ Anybody have any success in programming the transponder and remote for a '05 SC430? Does anybody know how many "keys" and remotes the system will accept? I've tried all the programming guides I can find (including the ones referenced in this thread) with no success. The closest I've found is the Tech Svc Bult EL005-01 (for the '01 and '02) whcih does appear to put the '05 into "ADD" mode for the remote but it will not "accept" the remote. +++++++++++++++++++++++++++++++++++++ I fianlly got one more key programmed and the remote working. The instructions on EL005-01 are correct BUT in my case I had to program the Wireless Remote BEFORE I could program the transponder in the Key. I used the key programming instructions from www.lexuskeys.com (Key Program 2) and that worked the first time but only AFTER I had the wireless remote working. Still not sure how many keys can be registered but at least I have two Master Keys now. I have one more I will try to register after I get it cut. Quote Link to comment Share on other sites More sharing options...
Brian Shaw1 Posted September 4, 2008 Share Posted September 4, 2008 Hey, if you all ready have a master key you can program up to 3 more keys. but its a two step process. first you have to program your key fob to lock and unlock your doors/truck. then you have to program the chip in the key to start your engine. Yes, you really can do this yourself. The following link is the very best fully detailed site i'll found to date for all lexus/toyota key/fob programing and best of all is 100% FREE :D I'am not sure how to post this link but here it is. just copy and paste to you address bar then ad it to your favs: www.toy-lex.com/programming Quote Link to comment Share on other sites More sharing options...
KENNETH DENTON Posted September 15, 2008 Share Posted September 15, 2008 Just bought a used 2002 sc430, great car btw, only had the one key so purchased through toy-lex.com, actually gave them the wrong key code and they sent me the right key at no extra charge, anyway, following the instructions for prgramming the key was very frustrating, I found that if you do it as quickly as you can it finally worked. forget 10 sec. to turn on and off, do it in six, and the open door and close door part, only open slightly and close a lot quicker than 35 seconds. in the end was very rewarding Hey, if you all ready have a master key you can program up to 3 more keys. but its a two step process. first you have to program your key fob to lock and unlock your doors/truck. then you have to program the chip in the key to start your engine. Yes, you really can do this yourself. The following link is the very best fully detailed site i'll found to date for all lexus/toyota key/fob programing and best of all is 100% FREE :D I'am not sure how to post this link but here it is. just copy and paste to you address bar then ad it to your favs: www.toy-lex.com/programming Quote Link to comment Share on other sites More sharing options...
LSKOCH5 Posted September 22, 2008 Share Posted September 22, 2008 Just bought a used 2002 sc430, great car btw, only had the one key so purchased through toy-lex.com, actually gave them the wrong key code and they sent me the right key at no extra charge, anyway, following the instructions for prgramming the key was very frustrating, I found that if you do it as quickly as you can it finally worked. forget 10 sec. to turn on and off, do it in six, and the open door and close door part, only open slightly and close a lot quicker than 35 seconds.in the end was very rewarding Hey, if you all ready have a master key you can program up to 3 more keys. but its a two step process. first you have to program your key fob to lock and unlock your doors/truck. then you have to program the chip in the key to start your engine. Yes, you really can do this yourself. The following link is the very best fully detailed site i'll found to date for all lexus/toyota key/fob programing and best of all is 100% FREE :D I'am not sure how to post this link but here it is. just copy and paste to you address bar then ad it to your favs: www.toy-lex.com/programming Wow, wish I had seen this before local Toyota dealership shafted me for exhorbitant charge for key then $90 to program!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
lobes Posted November 4, 2011 Share Posted November 4, 2011 Thanks for the information on how to program the key, I have a 2001 LS430 with only one key in Papua New Guinea, a country the size of France, this is the only 430 in the country and there are no dealers.If I want to take the car to a dealer, my nearest dealer is 2 days by ship and then more than 1000km away. when you purchase a new electronic transmitter with remote lock - unlock, boot opening, does this program as per download above let you operate all functions or only the ignition? are there cheaper keys available? I was quoted about AU$400 [uS$420] for a new key from Australia. regards lobes Quote Link to comment Share on other sites More sharing options...
