John Martin Posted August 15, 2006 Share Posted August 15, 2006 I have the cluster out, want to fix it if I can. I count 24 bulbs in the thing. Should I replace them all while I'm in there? Are they all the same bulb? Is there any significance to the colors of the bulb holders -- black, blue, gray, green? My odometer is dark, completely off. Can I get a replacement for just that part? From the dealer? Will I have to have it programmed at the dealer? (I don't really care about the mileage reading, it's the trip and distance parts I want.) Is there any common problem with the circuit board that is causing the odomenter to not work that I can repair? Other than the dead needles, is there anything else I should fix while I'm in there? Actually I do have one needle question. Should I use a clamp (surgical) to hold the needle posts so I know exactly where to reinstall the needles, or do they stay still after the needles are removed so all I will need is a picture? Thanks in advance, JM Quote Link to comment Share on other sites More sharing options...
slstsang Posted August 16, 2006 Share Posted August 16, 2006 I have the cluster out, want to fix it if I can. I count 24 bulbs in the thing. Should I replace them all while I'm in there? Are they all the same bulb? Is there any significance to the colors of the bulb holders -- black, blue, gray, green? My odometer is dark, completely off. Can I get a replacement for just that part? From the dealer? Will I have to have it programmed at the dealer? (I don't really care about the mileage reading, it's the trip and distance parts I want.) Is there any common problem with the circuit board that is causing the odomenter to not work that I can repair? Other than the dead needles, is there anything else I should fix while I'm in there? Actually I do have one needle question. Should I use a clamp (surgical) to hold the needle posts so I know exactly where to reinstall the needles, or do they stay still after the needles are removed so all I will need is a picture? Thanks in advance, JM I just recently replaced some bulbs in my cluster, i only replaced the rmp and speed lights, my other lights were fine. they were all the same voltage. there is no significance in the bulb holders color. i think the dealership will charge you for the whole cluster, they won't sell you just the odometer part. your best bet is get one from a junkyard. the needles are too expensive to replace, the cheapest fix is paint it with glow in the dark / florencent paint. then get those small LED lights that plug in your dash to light the cluster area. use the search function and look for remove needle instruction. Quote Link to comment Share on other sites More sharing options...
