Rear Suspension Boucing Around. Time To Replace?
Hello.
I just got a 92 ES300 with 138K miles. I noticed that the rear becoems bouncy/wobbly/loose when going over bumps as if the tires have too much pressure and bouncing like a basketball. I checked the tire pressure and it seems fine (30psi, cold)
Will the new struts fix this? Also, if I have to get new struts, I want to do other preventative repairs. What else should I change regarding the suspension? Mounts, busshings, springs?
Thanks!
Thanks for the reply.
Is there a way to find out what parts I need to replace for sure?
I suppose I can check and see if they sawy bar bushings and end links are bad?
Thanks.
Struts, mounts, springs all around.
I'm betting money you need sway bar bushings & end links.
And atleast the dogbone engine mount & front mount. :)
