John Martin Posted August 4, 2006 Share Posted August 4, 2006 I know that the rear valve cover gasket is leaking, and I may have a bad main seal. What I can't figure out is what could be leaking oil onto the lower block area below the oil filter. The immediate area aroung the oil filter is clean. Is it possible that something is blowing oil up on to the engine in that area? Thanks in advance, JM Quote Link to comment Share on other sites More sharing options...
GM1995ES Posted August 7, 2006 Share Posted August 7, 2006 I had the same quizzle last January - couldn't spot the oil leak at all. Turned out to be the Power Steering pump - about $500 at Toyota when all was said and done. I didn't have this problem, but previous posts have said that the PS fluid can do bad things to an alternator. Quote Link to comment Share on other sites More sharing options...
abrarcool Posted August 11, 2006 Share Posted August 11, 2006 could be the front engine mount it has oil in it Quote Link to comment Share on other sites More sharing options...
