How do you remove the headlight from the 02-05 ES300. I removed the 3 bolts from the top, but how do u get to the 4th bolt on the side? Do you have to remove the splash guard or something? Thanks for your help
In this thread is listing of service manauls you can download if you wish.
here
I have the 2002 shop manaul that I could fax you the pages from work on Monday. (sorry, no scanner in my house).
The 2002 manual says,
1. Remove the front fender liner (LH or RH)
2. Remove the front bumer cover.
3. Remove the 4 screws
The picture shows three easy to get at screws:
1. at the top of the light assembley
2. halfway down the inside edge
3 bottm inside corner
the 4th screw is to the outside of the low beam light socket on the side. It looks like the head of the screw is right in front of the quarter panel and is exposed when the bumer cover is removed.
Tough one to get at.
steviej
Thanks for your help. Im still a little confused. But if you could fax it to me monday i would really appreciate it. Just email me or PM and i will tell you my fax number. My email is chokeslam1999@yahoo.com
Thanks again
Thanks again
consider it done. expect a fax on Monday.
steviej
