ojairon Posted May 12, 2006 Share Posted May 12, 2006 I just bought a 1999 RX 300. I notice a slight vibration at idle. Could this be motor mounts? Quote Link to comment Share on other sites More sharing options...
chiks Posted May 26, 2006 Share Posted May 26, 2006 it is the resonance of the exhaust system. Most RX300 suffer from it. no known fix. but this TSB may work for you. NV011-98 Lexus Supports ASE Certification Page 1 of 2 Title: IDLE BOOMING/VIBRATION FIELD FIX Models: ’99 RX 300 Technical Service Information Bulletin August 14, 1998 NV011–98 To reduce noise and vibration at idle speeds, a dynamic damper has been added to the center exhaust pipe for both 4WD and 2WD models. 1999 model year RX 300: 2WD manufactured before VIN JT6GF10U*X0007065 4WD manufactured before VIN JT6HF10U*X0015585. OLD PART NUMBER NEW PART NUMBER PART NAME 17420–20130 same Pipe Assembly, Exhaust, Center N/A 17581–46060 Damper, Exhaust Pipe Gasket, Rear (17451–74060) Center Pipe (17420–20130) Damper Bracket Damper Gasket, Front (17451–20020) OP CODE DESCRIPTION TIME OPN T1 T2 NV8024 Install Exhaust Damper 0.2 17581–46060 44 99 170181 R & R Center Pipe Assembly 0.5 17420–20130 Applicable Warranty*: This repair is covered under the Lexus Basic Warranty. This warranty is in effect for 48 months or 50,000 miles, whichever occurs first, from the vehicle’s in–service date. * Warranty application is limited to correction of a problem based upon a customer’s specific complaint. NVH Introduction Affected Vehicles Parts Information Warranty Information Quote Link to comment Share on other sites More sharing options...
ojairon Posted May 27, 2006 Author Share Posted May 27, 2006 I just bought a 1999 RX 300. I notice a slight vibration at idle. Could this be motor mounts? Thanks of the information. I will check this out with my mechanic. My car now has 71000 on it so I am out of luck with the warranty. Quote Link to comment Share on other sites More sharing options...
