Question About Driveshafts
  • 1 year later...
i was just wondering if you guys knew if there was a difference in length between the sc300 driveshaft and the sc400 driveshafts.
thanks
eric
Did you ever have any luck with the drive shaft? I have a 94 sc300 with a 1jzgte and the drive shaft is a problem. It sounds like custom may be the way to go. Has anyone found a use able stock DS for this swap? Where's a cheap place to get a custom DS? This has to be a common problem on a very common swap.
