alexmw Posted May 9, 2006 Posted May 9, 2006 Hi all ! Id like to replace the factory amp which is located under the passenger seat with an aftermarket amp. has anyone done this ? Anyone have a wiring diagram of the factory fitted audio system? All help would be greatly apreciated! Thanks, Alex.
PIONEERSUBY Posted May 20, 2006 Posted May 20, 2006 Hi all ! Id like to replace the factory amp which is located under the passenger seat with an aftermarket amp. has anyone done this ? Anyone have a wiring diagram of the factory fitted audio system? All help would be greatly apreciated! Thanks, Alex. you can tap the right and left channel digital output of the factory amp and hook up a seperate amp but you cant replace the factory amp as it is the only amp the headunit will recognize and play
