remuspwr Posted April 23, 2006 Share Posted April 23, 2006 Sorry if this is a repost... I've tried countless search words/combinations, but came up with nothing. I'm looking to swap the tail lights from my 04' ES to the 05' style. I know the 05'/06' tail lights will fit the 02'-04', but does anyone know what to do with the wiring? Is it possible to use the same sockets or is it different? Any info on this is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
steviej Posted April 23, 2006 Share Posted April 23, 2006 I was going to do the same, but found the same dilemna. The sockets on the 02-04 don't fit the holders on the 05-06 light buckets. You would have to swap them. Plus the 05 buckets call for 1 less bulb than the 02-24 buckets so you would have a bulb loose behind the bucket. There was a member, I can't remember if it was here or on CL, that has done it successfully and it looks good but did require some manipulation of the wiring. I settled for a simple solution of using silver bulbs on my 02 to remove the fried egg appearance of the 02 tails. They look good in the front too. steviej Quote Link to comment Share on other sites More sharing options...
