mrnaasty Posted April 3, 2006 Share Posted April 3, 2006 how do you replace the foglight bulb on a 1993 es? Quote Link to comment Share on other sites More sharing options...
Toysrme Posted April 3, 2006 Share Posted April 3, 2006 The housing at the back turns & pulls off. Pull the wire & bulb out of the headlight. If you have to dorp the assembly out. It's just 3 bolts. Quote Link to comment Share on other sites More sharing options...
Lexucan Posted April 3, 2006 Share Posted April 3, 2006 I found that removing the whole assembly allowed me to clean up the lens and housing while changing the bulb. Like Toysrme said, it's just three #10 bolts per light. You might need an extension on your socket/ratchet though as at least one of the bolts is a bit hard to get at otherwise. Quote Link to comment Share on other sites More sharing options...
