I have been having an issue with my '94 LS400. When the car is cold - or it's cold out, my instrument panel will not light up. If I run the heat or if it is warm enough out, the panel will light up. Even if it is warm with the panel working and I run the AC long enough, the lights will eventually fail. Anyone run into this or know where the issue is?
Check the FAQ section or search for Jim Walker. You'll need to send out your cluster to get the problem fixed.
Pinned: Replacing Burnt Out Needles In Instrument Panel
...hit the "back button" and look at the top of the "pinned" section......your answer...
