Nashville-GS300 Posted March 13, 2006 Share Posted March 13, 2006 I have a 99 GS300 with 73k. The electronic A/C-Heater unit is stuck. Although I can adjust the driver side temp up or down, th epassenger side will only go up. Raight now it is stuck on 82 and will not go down. Also, I can not take it off "dual" setting. Has anyone else experienced this problem? Also, I was hoping that if I could cut the power to the unit, it might "reset" itself at a lower temp. Anyone have any thoughts on this approach? If so, does anyone know how to cut the power? I tried to pull the fuse and the one markd A/C (on the driver's side near the kick panel) did not do it. Thanks. Quote Link to comment Share on other sites More sharing options...
