2002 Sc 430 - Which One To Purchase?
Brianley
Hello all,
I'm going out this weekend to look at two 2002 SC430s within 50 miles of each other. Both are black on black (which is what I want), the 1st with 42k miles and aftermarket ziniki rims and "high performance Z rated dunlops". The 2nd has 35k miles and all stock components (run flats, spoiler, nav). Assuming I can get either car for about the same price (low to mid 30s) which would you recommend? Supposedly the after market tires and rims retailed for $8k, and they certainly look nicer than the stock rims / tires, but the idea of 7k less miles (probably 1/2 a year of miles with the amount I drive) is intriguing as well. Thoughts?
Depends on your taste, get the one with lower miles if it's super clean, and make sure it was dealer maintained with records and no accidents.. If the after market rims lexo with higher miles was maintained perfect and is simply a cleaner car and looks way better then buy that... The mile difference should not matter if the cars were maintained properly.. Good luck
