Rx330 Tow Hitch Harness Connector
tgrenwis
For those who have tried to find the Tow Package Harness Connector on a 2004 RX330:
It is located on the Driver side under the tire jack and tool compartment which is located above the spare tire. To get to it you must remove this tool compartment by removing the two plastic bolts on each side and lifting the tool compartment up from the rear. Once removed you will see a white plastic connector fastened to the left rear wheel well.
If you are adding a trailer hitch you will need the Lexus tow harnes, part number 08942-48870-BB.
