es300_md Posted January 12, 2006 Share Posted January 12, 2006 I need some help !!! I wrecked my 95 ES300 and I am trying to repair myself (I cannot afford to pay the high price of the body shop). I am an O.K. Mechanic willing to take a shot at it. I am in the market for a Radiator Support assembly and a shroud for my car but need some help on how to remove the current Radiator Support Assembly, especially the Upper Tie Bar. I have included some photographs, please advice and thanks in advance. wreck pictures Quote Link to comment Share on other sites More sharing options...
Toysrme Posted January 12, 2006 Share Posted January 12, 2006 (edited) Mmmmmmm Downlaod the '93 ES 300 FSM I posted & check the body stuff for info. You can also try the '94 Camry FSM that floats around. Techinfo.Toyota.com if you have to. Pay your $10 & spend enternity downloading every single manual for your car. I'll give it a quick look tomorrow, but I don't know of any obvious answer off-hand other than my personal motto, "A Sawzall, Solves All". Welding is kewl. Best I remember, there are some 10mm bolts that hold part of it on. Maybe you'll get lucky & that's all that keeps it on, IDK. Edited January 12, 2006 by Toysrme Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted January 13, 2006 Share Posted January 13, 2006 Mmmmmmm Downlaod the '93 ES 300 FSM I posted & check the body stuff for info. You can also try the '94 Camry FSM that floats around. Techinfo.Toyota.com if you have to. Pay your $10 & spend enternity downloading every single manual for your car. I'll give it a quick look tomorrow, but I don't know of any obvious answer off-hand other than my personal motto, "A Sawzall, Solves All". Welding is kewl. Best I remember, there are some 10mm bolts that hold part of it on. Maybe you'll get lucky & that's all that keeps it on, IDK. the sawzall is the only way to remove it, unless you unweld it, as it is tack (or spot) welded into place. once you have removed it, replace with the new one and weld in. this is the ONLY part of that repair i would let a body shop handle, other than paint. did the airbags deploy? Quote Link to comment Share on other sites More sharing options...
