Mr. B Posted July 23, 2003 Share Posted July 23, 2003 I just purchased a 94 sc400 and the stereo stopped working. When powered on, the station defaults to AM900 and I can't change it. When depressing the FM or CD buttons, nothing happens. I can't even change the AM station. The only thinh that will play is the tape deck. Can someone help? Quote Link to comment Share on other sites More sharing options...
bbsal Posted August 19, 2003 Share Posted August 19, 2003 hmm did you check all the fuses?maybe theres a seperate fuse for the cd and radio.i doubt it because you said it works with a tape but give it a shot.if not its probably burned out and in that case you will need a new one.check ebay and local junk yards for a new one.hope this helps Quote Link to comment Share on other sites More sharing options...
Mr. B Posted August 19, 2003 Author Share Posted August 19, 2003 Thanks for the response. I've found out what the problem was. The FM button was stuck. A lot of goop was packed in between the buttons. I cleaned around the buttons with a straight pin to remove the junk and everything works great now. Who would've guessed. Thanks again for the suggestions. Quote Link to comment Share on other sites More sharing options...
bbsal Posted August 21, 2003 Share Posted August 21, 2003 cool!glad it worked out for you! Quote Link to comment Share on other sites More sharing options...
